very confused
farmerehsan
144.6 db
Hey i need some help on a setup...real easy,
i have a Basspro ASA 1000.1D Ampilfier... first of all is it any good? IM looking for some good subs to get.. I like JL audio alot but which to get so i can use all the 1000 watts the amp has without blowing the speakers... this amp is 1 ohm for 1000watts
hows it better to do... 1 big sub or 2 smaller is in 10 or 12's?
any help plz?
Oic.
JL Audio is expensive, better options for the price.
I don't know much about the amplifier - if it does put out a genuine 1000 watts, then you have several options. 2 smaller subwoofers are going to be louder, and get you more sound for the power, but the larger one will get a deeper bass. Are you looking at the sound quality or SPL?
i have a nissan xterra, a little bit of both i guess...
SPECIFICATIONS:
• 4 ohm Power : 250W x 1
• 2 ohm Power : 500W x 1
• 1 ohm Mono Power : 1000W x 1
• Peak Power : 2000W
• Total Harmonic Distortion :
• Frequency Response : 20Hz - 250Hz
• S/N Ratio : >80 dB/W/M
• Damping Factor : >150
• Input Sensitivity : 0.5 - 4.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 40Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 40Hz
• Dimensions : 13.7" x 11.3" x 1.9"
• Dimensions : 350mm x 288mm x 48mm
i have 6x9 AND 6 1/2s and tweeters that are JL AUDIO! being pushed by a E1250 JL audio amp.....
so now that u guys say it pushes 700? would 2 w3's? be ok....if so what size? 10 12?
You can find a decent sub for around that price. A single Fi Q would be a good choice and probably wouldn't be much more then that. Maybe a single Audioque SDC2.5. Or you can look in the classifieds section on this site and find some good stuff for that price.
farmerehsan
144.6 db
farmerehsan
Tampa
BobbyDD
