very bad voltage drop on 1k rms
yeah something really wrong running a saz 3000d and fosgate 400.2 off stock 105 alt. big 3 and kinetik 1800 with now voltage drop below 13.5 and ur getting this off 1000 watt amp
id check the grounds. make sure the contact area is really clean of paint. make sure all your connections are tight. get the batts checked. a bad cell can cause a lot of odd things to happen.
Well then u either have a bad alt or bad batts. 1k on 2 batts with a 105alt and dropping to the 12's is not normal..
i would say. all the batterys in the back have 88 or more % life left. i was thinkin the wal mart batt in front is whats to blame. since i tested my electrical at my local auto parts place. the alt was only needing to put out 40 amps out of 105.
pretty sure that amp isnt one ohm stable. i might be wrong though but it could be drawing too much power more than it should
you are correct bro. alpine pdx 1.1000 is only 4 & 2 stable . anything else it does not like but will play no problems
yeah i know its bad. in my 98 malibu i had big 3 upgrade 5 runs of 4 gauge 8 ground 4 gauge wires one yellowtop in the back and runnin a soundstream xxx 4000d @ 2ohms 2200rms and i would only drop to 13.8-.13.5 even with a aq 2200 @ .5ohm was dippin to 13.5
ddfan24
ddfan24
San Antonio,TX
KTMrida4life
