vented enclosure for hd3 15
exportdrums11
I just got a hd3 15 and I need to build a box for it. I know on the audioque site it says 4.5 cu/ft but they don't give any port info. I've been told that I should tune this sub low so should I build a bigger box that 4.5cu/ft? If so what size and how much sq inches of port area should I use. I drive a 99 yukon, so it's a big truck, and I listen to all kinds of music. I'm trying to go for a good mix of spl and sq. I'm up for suggestions.
If you go to their website they tell you how to design a box for their subs. It is in one of the drop down menus.
Their recommendation is that you tune to around 40 hz.
DONT TUNE IT TO 40hz.....32-36 will be good.....
What the fuck do you know?
DJ says tune it to 40, everyone that owns it says tune it to 40. It peaks lower than tuning sometimes about 7hz below, so why tune it to 32-36?
BTW, I meant from how long you ordered it. I hear it takes a while for them to build it.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
654
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
exportdrums11
exportdrums11
lexington,ky
kicker06
Brendon Jenness
    May 8, 2024
    May 8, 2024
