if my amp turns on and has a green light then voltage must be reaching the amp correct? and the hu is sending a signal. and it is sending voltage to the speaker outputs because i used the reading to check my volts to set the gain for my amp. i must have just wired it wrong when hooking it back up, but i dont see how. maybe when i took the sub out of the box i re-rewired it wrong lol. i dont know.
You removed the sub from the box? That was unnecessary for setting gains. What sub/how many and what voice coil specs so we can be sure you have it wired right?
i have a mach 5 audio 10" IXL dual 2 and a planet audio bb1350.1b amp
i wired all the minus and all the plus so that should give me a 1ohm load to the amp. im going to go take the sub back out and make sure its wired correctly again and check my wires inside the car. i have made this so much harder and all i want to do is listen to my fuking system lol!!!
Wait is there a difference between a dmm and a voltmeter? Back when I tried using a voltmeter to set my gains with a test tone, the numbers would not stop jumping all over the place.
