Using CA accelerator???
JB513
OH
How do i use this? I have the IC-2000 CA glue and Insta-set accelerator from BSI. Do i put the glue down then the cone then spray the accelerator or glue accelerator then cone down? Please help!! I'm about to break my recone cherry!!
Is the accelerator really needed or does it just speed up the process?
And when you say brittle are you saying the glue becomes brittle or everything that the accelerator touches like the cone and spiders would become brittle if i got too much on them?
I dont use that much accelerator at all.. I just use it to help hold downt he surround if it dosent just stick using the glue... I spray a light mist over everything I glued when everything is good to go... I also let it sit for 24 hours since I dont use much accelerator..... The accelerator is good if you are in a Comp and u need to recone a blown sub fast to make it to the next round or run
I'll probably do what Korn said and not use much accelerator. We'll see how it goes. Hope for the best everyone!
JB513
JB513
OH
TSGP
