tc300 10+ year member
caps ARE a WASTE... if your electrical was up to-par, it wouldnt be needed or even thawt about!
I stopped here because this can't possibly apply to a car's charging system.
The cap won't even finish one discharge cycle because you have a battery sitting there with (relatively) infinite current at 12.5v. The cap will never have voltage lower than the battery.
That is one of the big problems with the application of stiffening caps in a 14v charging system. About 3/4 of the energy stored is below the lowest voltage of the system.
lol, fail!if you would like the output voltage to be lower than the battery voltage.
Sounds like you need to start surrounding yourself with more intelligent people. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gifIt's because he has a degree in Electrical Engineering that we are supposed to take his word.
I know several people that have a Bachelor's, however, these people are still complete idiots. A degree doesn't mean you're smart, it just means you paid a bunch of money on a piece of paper. What makes a person smart is their actual knowledge and common sense.
This is a prime example of taking what someone with a degree says with a grain of salt....in this case, I think a grain is a wee bit little.
is your girlfriend happy with the size of your penis? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifso should i get cap or not?
I used 1/0 in my 1997 Civic coupe and in my 2006 Mustang GT. For the Civic it may have been overkill, but I only wanted to pull the interior apart ONCE versus every time I upgrade or change my mind. I bet I have more wattage in unused equipment than you have currently installed in your vehicleI am not bashing you but read the entire thread. Some said your car has to be as long as a football field in order for you to need to use 1/0 wire.
WB
LOL at the avatorCaps server their purpose, but not to fix a shortage in power...
Well , that is an intelligent question. If this thread was completely on an intelligent level , some one would have ask what capacitor I was using and THEN and only THEN could you tell me you used the same capacitor only to continue having the same problems.//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gifHave any proof? Because I have numerous test results that prove you wrong.
besides your Devry degree?
That's if the alternator can supply enough current to the battery to keep it at 13.8V.... this doesn't always happen if large loads are placed on the electrical system as a whole.I stopped here because this can't possibly apply to a car's charging system.
A cap is charge in the begining form the battery with out the car started so therfore it gets it's charge from the battery and recharges from the battery .I want you to think about what you just wrote by posing a couple of questions. Where does the capacitor get its charge from? If your capacitor is constantly being drained due to a less than adequate electrical system to support the sound system, how long do you think your alternator is going to last?
