First of all, hello everyone //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I have an MTX TA3404 amp (100x4 RMS @ 4-ohms, 200x2 RMS bridged @ 4-ohms) with which I want to use the front channels to power a pair of components (in stereo) and the rear channels to power a sub (in bridged mode).
The sub is a Kicker CompVR 12" with dual 4-ohm voicecoils (wired in parallel for a 2-ohm load). Now, I'd like to run this sub off the bridged rear channels, but the amp specifications allow for only 4-ohms.
My question is: Can I still use the 2-ohm sub, but set the amp to a lower gain?
The way I see it, I could set the gain using a digital multimeter so that the voltage across the bridged speaker outputs is 20.00 volts and thus produce 200 watts @ 2-ohms, instead of the 28.28 volts at the manufacturer specified 4-ohms to produce 200 watts.
Would this be at all feasible? If so, are there any drawbacks to this?
Basically, I just want to do as much as possible with the stuff I already have, without buying a new sub or amp. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Thanks in advance
Thanks in advance
