Used TARAMPS HD10000 (Brazilian Amplifier) (1 Ohm Version)
mrfr3sh2def
MD
Used Taramps HD10000
This amp was purchased from Senchez "Sencheezy" Richardson in April 2016 and has only been used once for 30 minutes of testing at the TDH Jeff Lockhart Memorial Show.
Physical: 7/10
Mechanical: 9/10 (only b/c I misplaced a few set screws)
The amp works flawlessly. The only thing wrong with it is that it is missing a few of the set screws which I have attempted to show via the pics below.
Taramp's HD 10,000 Amplifier
The Taramps HD 10,000 is a new and improved addition to the HD series, replacing the previous 10k offering. Improvements include but are not limited to the addition of line out, a deeper power supply down to 9v, more efficient heatsink up to 10 degrees Celsius cooler, and components which are more durable against damage from vibration. These models also have a better low impedance and thermal protection circuit. An on-board voltmeter was also added. The amplifier's new method of component adhesion was tested for 48hrs straight and then checked for vibration damage and passed.
This is a true 10,000 watt amp. The new HD series amps are some of the best amps from Brazil!
Specifications:
Number of Channels: 01
Maximum Power @ 13.8 VDC - 1 OHM: 11995W RMS
Maximum Power @ 13.8 VDC - 2 OHMS: 8037W RMS
Maximum Power @ 13.8 VDC - 4 OHMS: 4661W RMS
Maximum Power @ 12.6 VDC - 1 OHM: 10000W RMS
Maximum Power @ 12.6 VDC - 2 OHMS: 6700W RMS
Maximum Power @ 12.6 VDC - 4 OHMS: 3886W RMS
Input Sensitivity: 250mV @ (-9.78 dBm)
Total Harmonic Distortion (THD): 0.3%
S / N ratio:> 95dB
Damping Factor: 450
Frequency Response: 5Hz to 15kHz
Crossover:
HPF (High Pass Filter): 5 Hz to 50 Hz (-12dB / 8th) Variable
LPF (Low Pass Filter): 50Hz to 15kHz (-12dB / 8th) Variable
Protection System: Short in output / High Supply Voltage / Low / Thermal Protection
Input Impedance: 18K OHMS
Minimum Power supply: 9VDC
Maximum Supply Voltage: 16VDC
Idle Consumption: 3.60 Amp.
Maximal Musical @ 12.6VDC: 539.5 Amp.
Maximum consumption in sinusoidal signal (1kHz) @ 12.6VDC: 1079 Amp.
Dimensions (WxHxD): 230 x 73 x 497mm
Weight: 6.7kg
$750
Shipping & Insurance Included within the US
Trust me!! You can't depend on rise. Just wire to 1ohm or higher you going to still see hella power!!!
**PRICE DROP**
I am willing to let this amp go for $720 flat (including shipping/insurance to anywhere in the US) if purchased on or before 8/14/2016.
**sorry not sure how to modify OP**
**PRICE DROP**
$700 Shipped & Insured on or before 8/18. The price will not go lower than this and will increase back to the normal price after this date.
First come first serve
I own one of the S.M.S.L SU-1 MQA MQA-CD DAC. I got it to play off my stable platter CD player, a Pioneer Elite PD-59 that I use as a transport to...
10
963
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
13K
mrfr3sh2def
mrfr3sh2def
MD
mrfr3sh2def
    May 16, 2024
    May 16, 2024
