Used Liquid Nails... Uh oh
I've had to tear apart boxes before, and if they were held together with liquid nails the bond was terrible. I could easily separate them.
Now titebond II on the other hand, that shit holds like a mofo.
(note that most of my enclosures do a 170 inside the box, LOTS of pressure)
Ive tore apart a few of my boxes from LN and literally had to get a sledge hammer to break the bond....
Maybe I just used shitty liquid nails? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Either way though, I find titebond easier to work with. Though the non-running liquid nails would be nice to have for assembling panels with multiple sides to glue at once.
I used LN and it was a fail 2 15" RE SE's had the port wall knocking against the side wall maybe it was just a shitty built box though but my next box after that was fine and I used titebond. its been a 2:1 ratio and LN has had a 0% Sucess rate for me
liquid nails works best when it sits for a minute or 2 before bonding. did tests on it and titebond at school. titebond had about the same strength ln had but with titebond you can attach as quickly as you want
I havent touched the stuff in a long time but iirc the bottle says not to use it on mdf, but people do and I guess it'll work just fine with the added support of screws. I'd suggest just using Titebond II from now on though.
that's for 1/4" mdf, not 3/4", I read the bottle.
I've used liquid nails and never EVER had a problem. This is for around 50 or so enclosures in the last 5 years
LN is fine for sealing around the edges but I wouldn't use it for bonding wood together as it doesn't penetrate the wood, it stays on top. I use the Gorilla wood glue, the white kind not that expanding crap.
muddin wolvy
muddin wolvy
Henderson, KY
groundpound4200
