Used Incriminator Audio I Series 10" subwoofer Dual 2 ohm - $65
Vertex Audio
Pro Seller
Supporting Vendor
Good condition; working 7/10 visual 8/10
PRODUCT DETAIL
Speaker Series
I Series
Model Number
I10-D2/4
List Price
$139.99
Product Shipping Weight
12 Lbs
PRODUCT SPECIFICATIONS
Driver Type
Subwoofer
Nominal Diameter
10"
Power Handling (RMS)
300 watts
Impedance
DVC 4ohm / DVC 2ohm
Sensitivity
87.3 dB 1w/1m
Frequency Response
24 - 600 Hz
Voice Coil Diameter
2”
Magnet Weight
90 oz.
THIELE-SMALL PARAMETERS
DC Resistance (Re)
8 ohms Series
Voice Coil Inductance (Le)
Resonant Frequency (Fs)
36 Hz
Mechanical Q (Qms)
4.79
Electromagnetic Q (Qes)
0.51
Total Q (Qts)
0.49
Diaphragm Mass Inc. Airload (Mms)
139 g
Mechanical Compliance of Suspension (Cms)
0.131 mm/N
Surface Area Of Cone (Sd)
380 cm2
Volume of Displacement (Vd)
BL Product (BL)
14 Tm
Compliance Equivalent Volume (Vas)
27 L
Maximum Linear Excursion (Xmax)
22 mm p2p
MATERIALS OF CONSTRUCTION
Cone / Diaphragm Material
Resined Paper Cone
Surround Material
Dual Voice Coil
Yes
Basket/Frame Material
Stamped Steel
Shielded
Rubber Magnet Cover
MOUNTING INFORMATION
Overall Outside Diameter
10.500"
Mounting Depth
4.875"
Baffle Cutout Diameter
8.75"
Driver Displacement
.10 cft
$65 shipped in con usa.
View attachment 26549486View attachment 26549487 (List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)).
Vertex Audio
Pro Seller
Supporting Vendor
Vertex Audio
Los Angeles
Vertex Audio
