Taramp HD 8000 1ohm.
High Definition and Maximum Performance – These high power line of amplifiers from Brazil bring you the best in engineering and power for your extreme car audio installations. Taramp’s has a well-deserved reputation for building high-quality, high-power mobile audio products. The HD Series amps are some of the best-selling models, with variable high and low pass filters (crossovers), extreme durability, while delivering more reliable performance at standard car voltage on the market today.
Number of Channels - 01
Max. Output Power @ 13,8 VDC - 1 OHM: 9595W RMS
Max. Output Power @ 13,8 VDC - 2 OHMS: 6305W RMS
Max. Output Power @ 13,8 VDC - 4 OHMS: 3646W RMS
Max. Output Power @ 12,6 VDC - 1 OHM: 8000W RMS
Max. Output Power @ 12,6 VDC - 2 OHMS: 5256W RMS
Max. Output Power @ 12,6 VDC - 4 OHMS: 3040W RMS
Input Sensitivity: 250mV @ (-9,78 dBm)
Total Harmonic Distortion (THD): 0,5%
Signal Noise / Ratio: >90db
Damping Factor: 400
Frequency Response: 5hz to 15khz
Crossover:
H.P.F (High Pass Filter): 5hz to 50hz(-12db/octave) Variable
L.P.F (Low Pass Filter): 50hz to 15khz(-12db/octave) Variable
Input Impedance: 18k OHMS
Protection System: Short into Output / Power Supply High / Low
Minimum Supply Voltage: 10,5VDC
Maximum Supply Voltage: 16VDC
Idle Consumption: 2,50 Amp.
Musical Maximum Consumption @ 12,6VDC: 431 Amp.
Sinusoidal Maximum Consumption (1khz) @ 12,6VDC: 862 Amp.
Dimensions: (WxHxD): 229 X 65 X 497mm (9.01 x 2.55 x 19.56 in)
Weight: 6,11kg/13.4 lbs
$700 shipped.View attachment 26549706View attachment 26549707View attachment 26549708View attachment 26549709
Damping Factor: 400
Crossover:
