use of multiple capacitors
Start by unhooking the boss then the fusion and proceed to place them in the nearest garbage can //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
seriously though sell the 2 caps to people you know not friends //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif and get you another battery //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hey you got some nice caps there. And for the close positive answer. I hooked up two Rockford fosgate 1 furad. HOw I ran it, I'm not sure if it's correct, but I'll explain it to u anyway. From Batt1 to fuse to batt2( back trunk battery), then batt#2 posi to cap1 posi, nega from batt2 to negative cap1. Then cap1 posi to cap2 posi, cap1 negative to cap2 negative., then cap2 positive and negative out to whatever u connect after that.
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
I was wondering if anyone has used multiple capacitors...if so how do u wire them..do them have to b the same size...i have a fusion 1.5 and a boss 8 farad..any suggestions
dude.. throw them away or give to the closet neighor with a walmart/best buy system.. do your big 3 and invest in a better battery under hood
corie_bergeron
corie_bergeron
eau clairie,WI
Bettr n' Revrse
michigan born
    May 14, 2026
michigan born
    May 14, 2026
