Use of Amps?????
amps are to amplify the signal sent from the deck as cleanly as possible..How do you know if you need them? If you put aftermarker speakers in your car you should have an amp especially if you get good ones.
Mike
Even if you don't have aftermarket speakers some cars come with amps already installed to do what mykeys said; Amplify the sound. Think of it in terms of a microphone. When u talk with out one your voice isn't as loud as if u have one. Same principle but a little more complicated.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
153
414
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
SpykedFlyp808
SpykedFlyp808
Waipahu, HI
gator4thehaters
    May 16, 2024
    May 16, 2024
