As far as amps...its either 1 monoblock...or 2 externally linked monoblocks.
· Street A Class – A maximum of 1 subwoofer amplifier (or 2 externally bridged monoblock amplifiers) may be used. A maximum TOTAL of 2 electrical conductors may be used to connect the amplifier(s) to the woofer(s). (Please see the definitions section for more detail regarding conductors.)
o One 12-inch woofer
o OR a maximum of two 10-inch woofers
o OR a maximum of three 8-inch woofers
Street Division Passenger Compartment Restrictions
3-8a Modifications to the passenger compartment are prohibited.
Additional Guidelines:
· The OEM headliner (or an equivalent replacement) must remain in place. Grille cloth, box carpet, etc. may not be attached directly to the sheet metal of the roof in lieu of the headliner.
· The OEM door panels (or an equivalent replacement) must remain in place.
· The OEM carpeting (or an equivalent replacement) must remain in place.
· Cut-throughs in pickup trucks are not permitted.
· Sound damping materials may be used to reduce vibration when installed in accordance with the manufacturer’s recommended installation instructions. The maximum total thickness of sound damping material applied at any given location may not exceed 5/32 inch (4mm). The sound damping application may consist of mat-type material, spray-on material, or a combination of the two. A maximum of 2 layers of mat-type material may be used at any given location, even if the total thickness of the sound damping material(s) is less than 5/32 inch (4mm).
· Expanding foam may be used sparingly throughout the vehicle to seal small openings or reduce vibration, but may not be used to fill voids or other large cavities (such as the dashboard or doors).
3-8b Nothing in the sound system may interfere with the normal use and / or operation of the vehicle.
3-8c Seats may be folded for competition, but may not be removed from the vehicle. Competitors who fold their seats must be able to demonstrate that the installation of the sound system does not interfere with the normal operation of the seats that were folded.
· If a vehicle has more than 2 rows of seating, then the additional rows (3+) may be removed at the competitor’s discretion.
3-8d If the vehicle is an extended-cab or king-cab pickup truck, then the “normal use” restriction for “jump seats” that are located behind the front seat of the pickup is waived.
· This waiver only applies to pickups that have “jump seats” located behind the front seat. The dBDRA defines a “jump seat” as an OEM seat that was designed to be folded up against the side or back of the pickup’s passenger compartment.
· Jump Seats may not be removed from the pickup, but they may be folded in order to accommodate the sound system.
