USACi New Classes and Power Ratings for 2007
All Street Beat Classes remain the same
Stock 0-600 1 amp max
Stock 601-1800 3 amp max
Stock 1801-3000 4 amp max
Stock 3001 up unlimited amps
Note: 3001-up only offered at triples, regionals and finals.
Modified 0-600 1 amp max
Modified 601-1800 3 amp max
Modified 1801-3000 4 amp max
Modified 3001 up unlimited amps
Super Modified 0-600 1 amp max
Super Modified 601-1800 3 amp max
Super Modified 1801-3000 4 amp max
Super Modified 3001 up unlimited amps
Note: Super Modified is an open class except for regionals and finals.
Port Wars open
Super Port Wars open
Amp ratings for the 2007 season will be the highest derived power rating based on the following formula:
1/2 ohm rating multiplied by .25
1 ohm rating multiplied by .40
2 ohm rating multiplied by . 55
This is effectively a max power rating system but done is a way so as to police the class and rating structure.
Furthermore. Any amplifier that retails for more than a specified dollar amount per watt (somewhere around $1.25 per watt) will be subject to testing and re rating.
Our Thinking: here it is..
Change just for the sake of change is worthless. There were some great ideas posed and soem very creaive ones as well. Like most great ideas many of had ways to get around the rules and create the same problems we have had in the past. We would like to thank all the members who helped us with great ideas. After reveiwing all of the responses we feel the above is in the best interests of the majority of USACI memebrs and the furue of this organization.
Thank you for your support.!
Ralph Randall
USACI
DISCUSS
rating system looks pretty stupid... But i guess the days of the 4ohm battle is over.
also i see the snivlers won their battle against the 2 amps in the 0-300 (0-600 now)
So what happens if u use a 2ch amp, i wonder how its rated
everyone will find new amp combos that work well for each class...
i wonder if ill be finding some cheap m1's //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
If I run stock electrical, (1) HCCA 275R at 1 ohm and (2) Type R 12's what class would I be in?
Now what if I ran (1) Orion Xtreme 1200 at 4 ohm with teh same subs what class would I be in?
I'm completly new to comps :p
Pretty shity if you ask me. Pretty much killed the 40.1 in ss 301-900 (now 60-1800) But 2 40.1s in 601-1800 FTMFW.
I show 1 40.1 sitting at 1,440 USACi watts next year. published 1 ohm is 3600, i'm out. I do believe IA was walking away next year too.
2 275's would be 960 watts so, 601-1800 class.
The other would be 480 so 0-600 class.
Chevyaudio
:poof:
Chevyaudio
Back in the Dirty BR, Louisiana
Chevyaudio
