US amps power output
ToyTundra
has a slanted soundstage
965
AZ
I was reading This PDF about the USA-50 and 50x amps. This is what i found and it confused me:
Rated Amplifier Output @ 4 Ohms per Channel:
USA-50: 50 Watts
50x: 100 Watts
SPECIFICATIONS:.........USA-50........................ 50x
Watts/channel
4 ohms:.......................25 Watts..................50 Watts
2 ohms:.......................50 Watts..................80 Watts
1 ohm:.........................80 Watts..................N/A
Bridged Output: 160 Watts 160 Watts
THD:
S/N Ratio: >100db >100db
So my question is whats going on? Do they use the lower power rating to keep that crazy low THD? Are they underrated by half, but they also tell actual rating(top quote)?
I've always wanted to try US amps' gear, but i dunno which rating to believe
http://www.usamps.com/old_site/technical/documentation.htm
The first quote tells *total* amplifier power @ 4ohm per channel.
(25*2 = 50, 50*2 = 100)
The 2nd quote tells power per channel output at a given impedance.
How underrated are they 10%, 20%, 40%, more?
Once i measure my current draw i'll decide if i should run a ~40-50 W (tweet) amp or a 100-130w (mids) amp.
wayyyyy underrated...i had the us 100 and us150 and ran 4 comp sets and 4 10's they get SUPER hot the 150 shut down every once and awhile but i had no cooling.
Probably cause you're running them at lower impedance than they can handle.... 4 comp sets? on one amp? hehe.
I like my 3.5K hidden under the driver's seat. Nobody knows where my equipment is. Always thinking it is in the bed of my truck. Nope. Two amps...
14
When you do find a new Ground spot look for something existing that is tapped. If nothing like that is available make sure you cleanthe area to...
13
There’s no question that that setup wouldn’t bump like hell. Those SALT amps are killer. If the new Origin subs are as good as the ETA subs were...
Run 4g for power (or 1/0 if you can). There is no downside to bigger wire, and you won't have to replace it if (when) you go bigger. Speaker wire...
878
ToyTundra
ToyTundra
AZ
ToyTundra
audiobaun
    May 19, 2024
    May 19, 2024
