US amps power output
ToyTundra
has a slanted soundstage
965
AZ
I was reading This PDF about the USA-50 and 50x amps. This is what i found and it confused me:
Rated Amplifier Output @ 4 Ohms per Channel:
USA-50: 50 Watts
50x: 100 Watts
SPECIFICATIONS:.........USA-50........................ 50x
Watts/channel
4 ohms:.......................25 Watts..................50 Watts
2 ohms:.......................50 Watts..................80 Watts
1 ohm:.........................80 Watts..................N/A
Bridged Output: 160 Watts 160 Watts
THD:
S/N Ratio: >100db >100db
So my question is whats going on? Do they use the lower power rating to keep that crazy low THD? Are they underrated by half, but they also tell actual rating(top quote)?
I've always wanted to try US amps' gear, but i dunno which rating to believe
http://www.usamps.com/old_site/technical/documentation.htm
How underrated are they 10%, 20%, 40%, more?
Once i measure my current draw i'll decide if i should run a ~40-50 W (tweet) amp or a 100-130w (mids) amp.
wayyyyy underrated...i had the us 100 and us150 and ran 4 comp sets and 4 10's they get SUPER hot the 150 shut down every once and awhile but i had no cooling.
Probably cause you're running them at lower impedance than they can handle.... 4 comp sets? on one amp? hehe.
ToyTundra
ToyTundra
AZ
ToyTundra
