el_chupo_
I recently bought a usx600d to power an alpine type r. The website says this amp is rated at 250Wx1 @4ohm, 375W x1 @2ohm. The manual that came with the amp states that it is puttng out 200x1 and 300x1, respectively, all at 12.9v. Which of these numbers is correct?
My other question has arisen because of a post on the board that said they used such small fuses(20 amp) because this is what is required for the 4 ohm load. I will be running the type r at 2 ohms, so do i need to replace the fuse with a bigger one? thanks
Matt
Matt
