UpGradde's 4th Order Build
UpGradde
Whats up yall. Started the box about 2 days ago, still need about another 2 days to finish everything. Its been raining but it'll be gone by tomorrow. This is my first 4th order enclosure, although I have built countless sealed and ported boxes. I am trying to keep this system lightweight, while still being somewhat loud. I had 2 Fi btls before but it was just too much weight for my car.
4th order is 1 cu.ft for the sealed chamber and 1.8 cu.ft for the vented chamber after sub and port displacement. It is tuned to ~43hz. 2 4" aeros. It is ported into the cabin via the rear seat armrest. Wat?
Build consists of:
  • 112 sq ft. of Dynacrap Xtreme
  • Pioneer AVH-P5100DVD
  • Arc Audio KS300.4
  • Hertz HSK 165 comps(newest model)
  • RE AX3200DE
  • TC Sounds Axis Neo 12
  • XS Power D2400 / Oznium interior & exterior lighting
  • Big 3 / All Knukonceptz wiring/rcas even the godam remote wire
PICSHURES:
The Car
House of Kolor Kandy Orange with a silver base
Inside the outdated 1991 M
Seats out of a 03 G35
Dynacrap every where.
Even the roof
My new Comps
Mids sealed like a muther****er
Crossover
A pillars gettin ready for paint and tweets
Tweets on the A pillars
Custom switches for lights, rad fan, and kill switch for bass amp.
Done, pasted with loctite superglue found at the Home depot
What the hell, it turned blue!
RE AX3200DE with plexi back cover
Se
Xy
Arc Audio KS300.4
Guts and fans
Gizmos and turbo switches galore.
My truck carrying a sheet of birch like it was a ****en paper clip.
The lightweight Beast
10" spiders
Hello, I'm Mr. Bass, how can I help you?
Cuttin the birch, tablesaw isnt pictured because its on tha flo.
Sealin the godamm trunk off, makin my angled cuts and thangs.
Aero Baffle
4th order gettin built.
Holes cut for Aeros
Test fit
painting the port baffle
painted and weater stripped
Would you look at that, it is basically sealed
testing the tubes, just for ****ing sakes
There she is, saying look at my titanium cone. U dont want this.
Bit of cement for the aeros.
This stuff stanks
Cement applied, even got my mirror to check around that hoe 360.
Ported chamber, threw in a led for red death ports
Sealed chamber.
Now all I need is to line em up.
There it is wow
Carpeted the box with carpet from PE
Creating the amp rack with the jig.
Made from 1/2" Birch
Getting ready to carpet
Done
Test fitting the Re ax3200de
Threw in an Antec 3 speed switch fan to expell that hot air
Test fit.
And thats it for now. It got dark on me. Tomorrow, I wire everything up and do some light testing. Hope
you guys enjoyed watching all these pics, it was hell to get em up here. Comments, critisism, opinions
are all welcome!
Edward
I like it. Kinda off topic...but i have an almost identical toggle bank in my dash ha. Except mine are 2 volt meters, and then fan. the mono killswitch is hidden.
I like the equipment and the willingness to go 4th order.
Craftsmanship is good as well.
props.
as stated:
UpGradde
UpGradde
Austin, TX
mbrooky
