i've been working a bit on the gain setting tool (see previous thread, i'll post link later when i'm not in links).
So far i've hit three concerns.
1.) of most importance, the opamp in question is not stable with the envelope detector load. I may have to abandon the opamp in favor of a different model, or discrete transistors. the opamp i typically use is a lm837n which is cheap and very low noise. its found in some commercial audio equipment as well (note that even the tru amps use "lowly" tl07x parts...). i was not wanting to use the lm324 opamp because it is class-C biased. the lm324 is more suited to 9V use -- the 837 is made more for traditional analog filtering, which uses 30V or so.
2.) the device will not work nearly as well with tube amps or amps expected to have unwanted even distortion. most solid state amps clip fairly symetrically which corresponds to odd distortion. to improve detection of even distortion, full-wave rectification is needed.
3.) i'm still tangling with the math. It should be possible to determine distortion less then a given percentage, but more difficult to know "how much less". bascially it has to do with phase issues and peak detection. the peak value of the distortion signal may be signifigantly higher then its average value. I've been working on a solution to this as well.
This will delay production a bit. i don't forsee any of these being impossible to fix, but at the same time they probably won't be solved until after christmas.
