Up front IB
josephharris
Ok maybe not a true IB set up but I think it will work with some proper tuning. I am using a Fi IB312 sub in a fiberglass enclosure (powered by a Kicker SX 650.1). I cut a hole in the front hump under the seat. I installed a shower drain over the hole and used a filter inside the drain. I will be using aircraft ductwork for the connection (drain to box). The sub fires at the dash (slightly upward); therefore I had 1" acoustic foam applied to the dash and then covered to match my new interior. Any thoughts?
josephharris
josephharris
Tennessee
josephharris
