unusual wiring question
bball09124
i know i could run one amp per coil and have each amp seeing 2 ohms correct? what the hell ohm load would this be? or is it even possible. if the sub is dual 2.
.5 ohms right?
Why would you wire it that way? What are you trying to do?
honestly, i was just seeing if there was a way to run two 1 ohm stable amps on a dual 2 ohm sub, with each amp running at 1 ohm. i really should sell the amp i have now and get one big amp opposed to buying another matching amp.
according to a reputable source on ROE that would be running the amps in parallel, and would most likely blow the amps unless they were designed to be run like this. makes sense.
bball09124
bball09124
psl, fl
Rawr-DQ
