A lot of posts while I was asleep, so I'll try to cover everyones questions..
My headunit has three bass features, but only two affect the actual sub.
Bass is set at -4, but that has no effect on the sub itself. I turned the speakers, put it to +6, and it did nothing for the sub, so I'm pretty sure of that.
There is a subwoofer seeting.
The Sub out is on.
The Phase is normal (yes i've tried reversing it, but to no audible difference.)
The level is at 0. I tried experimenting, and put the output to +2, and noticed a HUGE increase, but I'm sure it was because the amp was clipping...
Bass boost on the amp is 0. Changing the phase on the amp did nothing to audible difference.
There is an EQ on the headunit, called a Parametric EQ I believe?
For the Low setting, it DOES affect the subs output. I have it set on 0, and the Q Factor set at 40 hz, on 2 wide.
Also, what does this say for me being a bass head: I used to think my Type-R 5x7s had a decent amount of bass, and I just wanted a little more. I also thought my logitech subwoofer was pretty loud on my computer.
My rearview mirror does not even move. I'm really starting to think that I might need a more powerful amp. With my stock set up, I had just about no dimming, with only the Big 3. My alt is only about 70 amps. Once I upgraded to the Yellow Top, my voltage stayed at a constant 13.8-13.9, even with the sub on full tilt on music. Does that say anything at all, or is this just a decent eletrical system? I also have a 240 amp alt on the way from Thunder.
I'm going to go measure the aero ports and see exactly what it's tuned to.
