UNinstalling headunit
  • 4
brenTgrillzem
Flo-Rida
Hey guys, just bought a truck a while back.
It's the Sony XPLODDDDD //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif:crazy://content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif haha
I am trying to take the headunit out but when I pull the faceplate off and tried pulling the unit out it wouldn't slide.
So I looked online and it says you need these 2 realease keys to pull the unit out...
Is their something else besides the 2 release keys I could use to pull it out? Like a ruler or something idk..
wal mart has them. so does napa, advanced auto, and others. better to spend 5 bucks and get the actual tool than to try and use a coathanger.
If the truck has a "sony" headunit in it...you will need the "sony" removal keys...
depending on what type of truck it is, you should also be able to take apart the dash to get the dash kit out...then remove the radio from the kit....
So pretty much anything, GM, Dodge, Import for the most part will have a kit.... if it is an older Ford then you might not have a kit, and will have to locate some "keys" to unlock the unit out of the mounting cage.....
Where your cup holders are there should be 2 phillips screws...take those out...put the truck in gear and carefully pull the dash trim towards you....it will unsnap...them remove the 2 10mm bolts holding the dash kit in the dash....
394
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
987
brenTgrillzem
brenTgrillzem
Flo-Rida
Innovative:Cory
    May 12, 2024
Brendon Jenness
    May 11, 2024
