UNinstalling headunit
brenTgrillzem
Hey guys, just bought a truck a while back.
It's the Sony XPLODDDDD //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif:crazy://content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif haha
I am trying to take the headunit out but when I pull the faceplate off and tried pulling the unit out it wouldn't slide.
So I looked online and it says you need these 2 realease keys to pull the unit out...
Is their something else besides the 2 release keys I could use to pull it out? Like a ruler or something idk..
If the truck has a "sony" headunit in it...you will need the "sony" removal keys...
depending on what type of truck it is, you should also be able to take apart the dash to get the dash kit out...then remove the radio from the kit....
So pretty much anything, GM, Dodge, Import for the most part will have a kit.... if it is an older Ford then you might not have a kit, and will have to locate some "keys" to unlock the unit out of the mounting cage.....
Where your cup holders are there should be 2 phillips screws...take those out...put the truck in gear and carefully pull the dash trim towards you....it will unsnap...them remove the 2 10mm bolts holding the dash kit in the dash....
brenTgrillzem
brenTgrillzem
Flo-Rida
Innovative:Cory
