Uneven excursion
Hello,
I have a question about my two 12s and their uneven excursion. The difference in excursion is not major and the reason it is happening is because one of the subs was recently reconed and the rubber surround is somewhat stiffer and possibly thicker than the older rubber surround. The subs hit at the same time but the older sub seems to continue moving after the new sub has stopped. My question is, am I losing significant dbs because of this and should I replace the old rubber surround to even it out.
Thanks
It may be because of the box design and the way the pressure in the enclosure is unloading. If it was a sealed enclosure, then I would likely think the issue is either one of three things....spider is physically softer, coil might be weak/damaged, or air leak. The surround is an unlikely culprit.
It is a vented enclosure. Also the stiffness of the surround can easily be felt by touching the two. So, while it may be compunded by some of the things you listed, I am quite positive the rubber surround plays a role. They are mtx 9500s so the rubber surround sticks out and you can pinch it between your fingers feeling the difference
My thoughts as well.
Regardless of the quality of the subs, my original question was am I losing significant db. And should I have the older one reconed as well to resolve this. Thanks for the unsolicited opinion about my backup subs tho, greatly appreciated
powda-n-chowda
powda-n-chowda
Minnesnowta
powda-n-chowda
