Underrated, overrated... How do you know?
for example-
34 volts peak is recorded, channel is connected to a 2 ohm speaker/load
peak volts squared
34X34=1156
divided by resistance
1156 / 2= 578 watts
Peak output recorded as 578 watts, to obtain RMS voltage multiply by .727
578x.727= 420 watts rms
the multiply by .707 is for RMS Voltage, for wattage you just divide by 2.
PeakWattage/2=RMS Wattage
PeakVoltage*.707=RMS Voltage
//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
"the multiply by .707 is for RMS Voltage, for wattage you just divide by 2."
I learn somthing new every day, I found the info for the do it your self wattage check from Concept's website, I knew it was innacurate but I didn't think it was that far off!.
Just goes to further prove that you can't believe everthing you read.
Thanks for the update //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
anders213
anders213
Singapore
jsloan10
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
