under powering a sub ....
brian84corvette
hello all.
im almost 100% dead set on getting a mj 18. = BUT =
its rms is suposed to be around 700w and its single 4 ohm.
my amp is hifonicx bxi1206d wich suposedly gives off......
450w at 4
900w at 2
1200w at 1
hooking them up together = me feeding a 700w rms sub 450w
if my amp even puts out that much.
im not going for extreme kill you bass, but I do like some noise
and shake in the car.
how bad do you think its going to **** off of around 450w
or do you think I should hold out and try to find a good deal on a used
sub around here in the classafieds ?
it won't really be that bad to underpower it, as long as you're smart about it. But you can generally find a 2ch. amp that will do that power bridged at 4ohm for a decent price in the classifieds. I think that's a better route to go
hello all.
450w at 4
900w at 2
1200w at 1
what you describ here is totall different than your sig. Do you want to be loud? If so you need to use your power. You don'y need 3 sets of comps, get 1 decent set, and buy a decent sub with the rest.
1 good 15" dual 2ohm in a good ported box will do the trick;)
brian84corvette
brian84corvette
coral springs FL.
dave_damage
