um...help?
DeLaRosa25
Ok i was real eager to get my sub going again and my dumbass is outside about 1hr ago..with lil light snow/rainish out..i was about to connect the wires to the amp (the woofer wires)...and a spark came ...i dont know if it was because of the rain or was because i accidently touched the lead wire i think with the neg or pos of the woofer wires.....did i like..break anything again or will i be fine..im going to wait untill i get into a garage or something this time instead of being stubborn and yea..i tried hooking the wires up and woofer wouldnt kick..i couldnt really see if it was in the pos or neg..or i did both wires switched them..you know...if the two wires didnt work in the spot..switch them to the other side so the neg would be pos and the pos would be neg...wiring in the box is just fine...
I have a kicker 10" CVR
10" SUBWOOFER
MAXIMUM POWER 600W PEAK
MAXIMUM POWER 300W RMS
4-OHM DUAL VOICE COIL
FREQUENCY RESPONSE 25-500 Hz
And a Kenwood Amp KENWOOD KAC-6202
Performance
RMS Power Output (Watts x Channels) 60 x 2
Frequency Response 20-20k Hz
THD at Rated RMS Power 1%
Signal to Noise Ratio 100 dB
Input Voltage 14.4v
Peak Power Output (Watts x Channels) 200 x 2
Power at 2 Ohms (Watts x Channels) 100 x 2
Bridged Power (Watts x Channels) 200 x 1
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
Features
Amplifier Class AB
Tri-Way Capable Yes
Low-Pass Crossover Frequency 50-200 Hz
Low-Pass Slope (dB/octave) 12 dB
High-Pass Crossover Frequency 50-200 Hz
High-Pass Slope (dB/octave) 12 dB
Bass Boost No
Bass Boost Frequency N/A
Fan Cooled No
Fuse Rating 25 x 1
Speaker Level Inputs Yes
Preamp Outputs No
LED Power Indicator Yes
Width (inches) 14-11/16
Height (inches) 2-3/8
Depth (inches) 9-9/16
dont know exactly how to use them..I just touch the end of the multimeter to the coil?...I know some of them have different like..programs or whatever you have to set it to..well for cars you have to at least some..
Worth repeating...a DMM is basically required if you install anything yourself.
You have no business doing this yourself otherwise.
Set the multimeter to its resistance setting (should have a little Greek omega letter, and probably a few range selections if it's not autoranging), and touch both probes to the terminals. If you don't get a value, adjust the ranges until you get the correct one (ohms, not milliohms or microhms).
X2.
Once you purchase one, you'll be able to figure out how to use it. It will probably come with instruction manuals and what not too.//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Ok another thing..the wire you run from the subwoofer to the amp...can I just get that anywhere? Because I installed an amp rack and just re-used all my old wires and they dont reach far enough...What kind should I use...
DeLaRosa25
DeLaRosa25
Saginaw,MI
DeLaRosa25
