Sold UL12 really need to sell tonight
bones22
Critical Mass UL12
$575 shipped to the 48
FIRM
RMS Power handling: 2500 Watts (undistorted power)
Peak Power handling: 5000 Watts
Recommended Box Volume: 1.2 cuft. (Sealed)
Weight: 16.6 lbs
Motor Type: Dual Gap / Internal NEO Magnet
Voice Coil Type: Ultra-High Temp Dual Coil (Made in the USA)
Voice Coil Diameter: 3”
Voice Coil Impedance: 1.5 ohm nominal per coil
Xmax (one-way linear excursion): 36 mm (3” peak-to-peak)
Maximum Excursion (one way): 46 mm (Almost 4” peak-to-peak)
Sensitivity: 96.7 db (2.83V / 1m) (coils in parallel)
Fs (Klipple-LSI): 31 Hz
Qts (Klipple-LSI): 0.81
Vas (Klipple-LSI): 47.7 Liters
you can see there are some very small scuffs on the bottom of the motor from when i was going to put them in my truck. never got around to it though.
coils both read 1.6ohm
the damage to the box that i have for this one since i used the other box to ship one.
i will be adding plenty of extra packaging to insure the sub gets there in 1 piece. i will also get some make sure the seam of the box is glued back together well.
out of all the people who said they would be interested none as much as replied to it. i wasnt going to leave it up and be required to check it every day when nothing was happening.
i see...i dont have the power for her, or else d be interested. glws.
bones22
bones22
in my house
bones22
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
