Type-Rs vs P3s?
jero0ome
Between Type-Rs and P3s, which set up should I go with...
[2] Alpine 12" Type R SWR-1242D
[2] Alpine V-Power MRP-M850
[2] Rockford Fosgate 1-Farad Capacitors RFC1D
[1] Rockford Fosgate 4 Gauge RFK4D
[1] Enclosure unsure.
or
[2] Rockford Fosgate P3D412
[2] Rockford Fosgate P1000-IBD
I am also unsure of the type of enclosure to put these two subs into. I drive a 1997 Mitsubishi Montero. Thanks for the input.
I say..
Setup 3!
The 2 type R's..
A bigger amp..
No cap.. possibly a battery? Or HO Alt.. althought your not pushing a whole lot of power..
The biggest wire you want.. 4awg will probably work.. bigger is always better //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
And a nice ported enclosure.. that some TypeR fanatics will recommend (not me)..
I say search around for what some people with some R's are using, or recommending.. and see from there.. good luck with the build!
Andrew
I've heard all three, and had Mach 5 Maws. I say go Maws, but I'm biased. They're cheaper and sound more crisp.
Plus they are a shit ton cheaper. Aaaand you'll be probably the only one around with them.
As said before don't do a cap.
I'd rather go for a mono block amp instead of an amp for each sub.
Maybe the RF T5001BD or Kicker zx/kx1500.
4ga is fine for wiring.
In the wiring section you could take a look at the Big 3 thread. I didn't do any of that (big 3, h/o alt) on my T10001bd and I never got any dimming, but I don't know what amperage your alt runs at.
Just be safe and do the big 3.
Hope that helps.
jero0ome
jero0ome
Seattle, WA
jfsh90
vegang
vegang
