TYPE R setup???
haha alright
got an opinion on my 133.9 score with 1 12?
i had the bass on H/U down to -4 bass boost all the way up....
gain all the way up.... i know i shouldnt have it all the way up ive changed it since but still
and the sub was getting 1100 rms at 2 ohms in 1.25 cubes sealed
think thats good or could it b better with the settings right?
yes i have done 133.9 with this setup i promise!
check my sig....i did it at a comp over at Bunnell florida last month hosted by southeast SPL
im going the 21st of this month to doing 120-129.9 bass race class
i did do 133.9 with the back seats folded down and the sub facing the rear....(that board around my box that i mounted my amp on most likely is making me a few dbeez less to....
01 s 10 was there if u really dont believe me
my volume was at 50/50 also
It needs work. Not to sound rude, but that's a very low score, even for daily bumping. You should be in the 140's with a better box.
ok did i not say it was only in a 1.25 cube box? which id say is why its so low on 1100 rms at 2 ohms
but if u think it could still b higher with this box what would you suggest i change?
my setup is whats in my sig
I just totalled my Altima last year, it was a 99. I had a 5cuft ported enclosure in it for 15s, subs up/port back and it slammed. I could've gone a bit bigger, but I have a child and needed room for the stroller. You could do 5-6cuft easy in that trunk and seal it off to the cabin. Don't underestimate those trunks, they are larger than you may want to believe. Do the 2 12s ported in about 2.5cuft each on that 1608, 750 per sub would be great
alright sounds good ya i think my problem right now is that board i mounted my amp on that... i posted pics earlier of my trunk if u wanna c but ya i hit that 133.9 on the TL with the sub facing the trunk... thinkin i should have tried facing it into the inside probly losing a few dbs facing it away since i ahv that board sort of acting like a dampener?
what kind of numbers did u do with your 15s?
I could probably do a 150 in the kick with a single type r 12 and maybe a 147-148 at the headrest. Subtract 2-3 dB's from those scores since you have a trunk and that's what you should be capable of.
dang really?!? that woudl be with a ported box tho right?
waht do you think about the set up i ha eright now in my sig?
ill have new numbers posted after the 21st im gunna try turning my sub facing into the car isntead of out toward the trunk... i might have a some scores using a ported box 01 s 10 is going to let my hear too....
got any pointers that i could improve my scores with the set up i have rgiht now without buying all new stuff???
jbsilentkill
jbsilentkill
Apopka,FL
jbsilentkill
BP1Fanatic
BP1Fanatic
