type r sealed
Reit38
Total MindFawk
500
IA
right now i have 2 12s in a prefab i have only 38wide X 16 high X 18 deep to work with so im thinking of going sealed for my 2 type r 12's '04 pushed by a rockford 750s 2 channel
should i just make my box to fit that
also should i do 1 or 2 chambers
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Im dealing with type-r box questions myself right now, so i dont know how much help i can be, but i think for sealed, you would want seperate chambers so the subs are "fighting" each other. Alpines manual tells you the "optimum" diamentions of a sealed enclosure for one sub. I would just double that up and let them share the center baffle.
if you are dead set on going sealed the recommended specs per sub is .7cuft-1cuft
i would definately go ported if you have that much space... i have moe lester's 4.4cuft ported box tuned at 32hz and it is badass to say the least! check it out, there is a thread that is labled box plans and it is sticky'd at the top of this forum... that is what i would do if you have the space.
And to add my $0.02 to this thread there have been user after user after user reporting considerably less than positive results running Type Rs in a sealed configuration.
I have no experience with any model of the R myself but all the press on them would indicate that they much prefer a vented alignment.
are any of those plans going to fit my demensions tho
and still sound half way decent
thanks for the help guys i was under the inpression ported = big box & lots of space
Reit38
Total MindFawk
Reit38
IA
Reit38
