Type R isnt LOUD
Diablo6699
I just hooked up my 12" dual 2 ohm type r to my profile ap1200 and it is bridged at 4 ohms to give the sub 600 watts rms. but when i turn it up, it is no louder than the 100 watt rms amp that i had hooked up to it the other day. I got 4 gauge wiring and the box is 2 cu ft at 32 hz, but it is not loud at all. Anyone know what the problem could be?
Double check your wiring.
my wiring goes + on batt to inline fuse holder, then to distro block then to amp. the amp is grounded. rca to hu, remote wire to hu, + on amp to + on sub, - on amp to - on sub, then + on sub to - on sub.
Sounds like you NEED TCAB.
If you absolutely can't figure it out, PM NGSM13, he'll probably work on it for a small fee. He lives at UC, so he might be close to you.
I have a the same sub in the same box getting 531w with 4ga. and mine gets pretty loud off of that power, the way you have it wired sounds right
But just curious, when you say
You dont have the +&- from the amp running to the same voice coil do you?
It should go + on one v.c. and - on the other with the bannana clips going to the +&- in the middle
TCAB..duh
but just check all your wiring, and turn the gain up evryone knows whats its for durh, max it out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
158
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
532
Dammned that looks awesome. be a great picture in a workshop!! I have maybe 6 steel ratcheting type clamps, if that. much like the ones you have...
705
If you want something weather resistant, get a marine amplifier.
Diablo6699
Diablo6699
Youngstown, OH
Worlddre
audiobaun
    May 19, 2024
    May 19, 2024
