Two subs/Two Different amps....
What if I change the gains on the more powerful amplifer... do you think I can set them at the same level? - thx for the help
welll thats the problem is setting the gains right. Itd be hard but u could probly do it to a point where u wont notice a difference. Itd just be much easier to use one amp.
if that is what you end up doing, i would strongly reccomend using a different chamber for each sub because the sub getting more power will kick the hell out of the other sub if you use a common chamber.
If you want to ensure that both amps put out exactly the same amount of power, get a multimeter and measure the power coming out of the amp (WITHOUT THE SUBS HOOKED UP!). Adjust the gains accordingly. Note that you need to be playing a good test tone while doing this to ensure a constant input voltage.
Of course, I'd really suggest keeping the subs seperated anyway, just in case.
Well the speakers are in a seperate chambers so thats not a problem... maybe i'll take awalbert88's advice but i dont have a mulitmeter so that might be a problem. Right now the amp im using is working fine, it's just id rather divide the load and i think my speakers are clipping b/c the amp isnt putting out power fast enough b/c it is working too hard. I dont wanna kill my speakers and i do have an extra amp sitting around doing nothing... [How do I know my speakers are clipping?] But all of your replys are very helpful thanks alot!!
if you have the other amp just lying around and want to use the 2 amp setup you could try selling the extra one and getting one identical to the one you are using.
-Mac
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
134
16
423
568
ssj2xxgotenxx
The Chan Man
ssj2xxgotenxx
Bay Area
Mac11
    May 18, 2024
    May 18, 2024
