two sets of outputs on a sub..how do i wire it to the amp?
ltz
I have a pricision power pc 124 12" sub im wiring to 800w sony xplod amp. I'm only wiring the amp to this one sub, the sub has two sets of outputs, (1 set black and red, and another set of black and red on the other side of the sub) How do i wire it at 4ohms bridged to my sony xplod amp?
depends on ohms.. if its 2 ohm amp and 4 ohm sub bridge.. if its 2 ohm voice coil sub and 1 ohm amp bridge.. if they are the same parrallel... to bridge run wire on sub from black to black and red to red.. then run wire from one of the reds to amp and one black to amp... to parallel run one red to black and the other red and black go to amp...
Well, its a Sony so it isnt stable below 4ohms anyways. And if the sub is dual 4, he is going to have to wire in series at 8ohm. Even if its dual 2, he needs to wire series at 4ohm.
ltz
ltz
saginaw,mi
keep_hope_alive
