Two or one ohms!
  • Thread starter Unregistered
  • Live activity
  • Replies 1
  • Views 687
U
Unregistered
Guest
How's it goin everyone. Now this is a topic of constant debate between my friends and I as well as the audio places like Tweeter. What ohm load does a two channel amp see when it is run in parallel w/ two SVC subs. Some people say it is 2 ohms... others say it is 1. I've always thought it to be a 1 ohm load. That leads to another quick question if anyone has experience w/ the Excelon X401M mono block amp. It states that it is 2 ohm stable. If two SVC subs were run in parallel to it, causing it to see a 2 or 1 ohm load(still in debate), does it go into thermal protection for seein a 1 ohm load?
It's not a subject for debate. It's science, Physics, mathematics, whatever you want to call it. Universal truth.
Putting resistances in parallel follows the Law of Reciprocals. In mathematics terms:
1/Rt = 1/R1 + 1/R2 + ....1/Rn
Where Rt = the combined total, R1, R2 etc are the resistances.
For the simple case where two equal resistances are put in parallel the combined total is 1/2 of the value of one resistor.
e.g. Two 2 ohm resistors in parallel is 1 ohm, two 4 ohm resistors in parallel is 2 ohms, etc.
You didn't specify the impedance of the SVC subs so I can't answer the 2nd question. If they're 2 ohms each than it'll be a 1 ohm combo which would give the amp indigestion.
Guest
maylar
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
