two of different kind
spacegear
i have two subs im planning to use in a single box. they have the same power handling, same size. their difference is their brand and their coils. the 1st is SVC and the other DVC.
my plan:
series DVC = 8 ohm load
then, parallel wire it with 4 ohm SVC. whats the final load?
?? is it ok to use different subs at all?
dont do it, dont even think about it. Just cuse they're the same size and have the same power handling does not make them the same subs. Gonna sound like crap
UNLESS
u have a switch to make sure only 1 sub plays at a single moment. (ie switching from one sub to the other)
If you had two different subs that magically had the same T/S parameters, then you could do it just fine.
In this case, it'll not only sound bad, itll look like *** //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif//content.invisioncic.com/y282845/emoticons/blackeye.gif.66a1670f5aaf7f406e783a63e3387dc5.gif
Hell, it's hard enough to find two of the same sub that has the exact same t/s params. I haven't seen two matching subs that have the same DCR
exactly. With different VC configs and DCR, they'll be recieving different amounts of power. Even if they are the same sub, one SVC and one DVC it would be a horrible match.
theyre in a single box but diffrent chambers. it even has diffrent ports. but u sed no. so i do nothing. m just a newbie. this is my 1st bad *** install. just w8ng for a few grand plus. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif what equipment? install pics?
what i meant with bad *** is music that could be heard down the street. wen ur inside my cabin. u wont think that it has an amplifier. i mounted them under the seats and the speakers are under the door panels. sleeper....the only thing obvious is my sub. pics will come later. m using kicker, alpine and blaupunkt.
spacegear
spacegear
Ozamiz City, Ph
spacegear
vegang
vegang
