Two batteries/ Does it help?
not unless you beef up your alternator.
but with your set-up, it might. You're not running a lot of watts.
It will help voltage drops, but from what I've read, it does not stop light dimming.
Well my new setup will consist of an Alpine MRP-M1000 w/ 2 Alpine Type R's lol right now I have a little sub pushing 300 RMS to it and my lights dimm, so if I have a 1000 RMS i need to fix this problem lol can you have a red top battery in the front and a yellow top battery in the trunk?
Thanks mccanng
i believe the alternators in solara's are TINY, so the battery will help, but only so much.
you need something to charge batteries as well. I would grab another battery, than if you still have dimming issues, get an alternator.
If it came down to a new alternator how many amps should it be for it to be fine with my new setup?
Thanks mccanng
Thanks mccanng
If you do decide on an alternator, make sure it's one that would satisfy you current system electrical currents, and if you decide to upgrade later down the road. IMO I'll get a 200a alternator. Maybe a Lil' big right now, buy it's a size you could upgrade on later.
I think it is an 80 amp alt. And can you have a red top in the front and then a yellow top in the trunk, or no?
Thanks Greg
Would a 130amp alternator be fine for the new setup or need more amps?
(asking because they are only 200 compared to a 200a for 600)
Thanks Greg
Would a 130amp alternator be fine for the new setup or need more amps?(asking because they are only 200 compared to a 200a for 600)
Thanks Greg
where are you getting your quotes from?
They should be a good bit cheaper than that.
Look into:
DC Power Engineering
Iraggi
Db link
Those should all be cheaper than 600.
mccanng
Car Audio Learner :-D
mccanng
NC
loopkiller
Mike Mccabe
