Two 15 inch strokers...what happened......video inside
I dont get it //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
you dont HAVE to set your gains with a DMM, but if you dont you should be very conservative and keep them low.... being no where near or > than half.
says who?
His subs are rated at what.....2000rms at piece and he only has a 2600watt overrated amp on them....id say a bit over half is conservative enough for that particular setup
says who?
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
does his deck only output a volt or 2?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Who knows....either way...safe
Considering everything else is in tip top shape
Yeah the only thing i could think also would be clipping, because there is no way that amp would blow those subs, unless the strokers are very over ratted??
not sure if theyre overrated but i know they cant take a 4kw on each coil for a burp:cool:
i dont know u shouldnt be able to fry those in twenty minutes no matter what unless it was something extreme
ive ran cheaper speakers not having any idea what i was doing on there full power and they played for atleast months
did u have the speakers wired correctly
crownvicdriver
crownvicdriver
Huntsville, AL
moh.vze.com
