Twisted Sounds or Synergy
I have run this amp at 1ohm on a Soundqubed HDS315.
But maybe you guys are right. Maybe just hold on to it and wait till I get the new subs and enclosure and see how it sounds.
So what's missing? You have 1 sub in your sig, then you said you're gonna run the DB drives, now you have the HDS. So which one are you hooking it up to? What are your box specs? For all of these?
Okay...
Started with this Sundown SAZ1500v3 running a Soundqubed HDS315 at one ohm. Could not stand it. Made noise and thats about it. Changed out the sub to this Exonic EXS10x in a Starr Mountain Sound enclosure at 2 ohm and loved it. So I sold the Soundqubed 15. Now wanna add a little more bass. Not alot but a little. So I bought two dbDrive WDX8's and have Brian building me another enclosure.
The HDS315 was in 4cu.ft tuned to 37hz as they recommend
The Exonic is in 1cu.ft tuned to 34hz
The dbDrives will be in 1.8cu.ft tuned to 32hz
Okay...
I think going from 37 to 34 is a noticeable difference. This also has nothing to do with the amp. I've heard a few HDS subs - a 310 and a 312, both sound pretty **** decent. Of course, neither of them live in a box tuned to 37. I like 32. Don't buy anything, just wait for your box and stick the sundown on those DB drives, I bet you'll be happy.
I know people have noticed differences between mids/highs amp right out of the box, but with sub amps it all boils down to power and damping to some extent. With sub amps, there's no sound stage, there's no imaging, so you just need an amp that will:
1. Provide ample power (preferably efficiently).
2. Control the speaker well (good damping).
3. Will be reliable (will last) and hopefully will be priced competitively.
I didn't realize there wasn't anything wrong with the saz
I'd suggest that you could gain some noticeable improvement in SQ by buying an amp that would deliver the same power but running higher impedance, but just swapping out cookie cutter Korean 1.5K amps will achieve absolutely nothing. You'll want to double your amp budget if you want to hear any noticeable difference. I'd even agree with the consensus here that just stepping up into a 3K would probably be worthwhile for you. Used legit 3K amps can be had for low 400$ range if you shop around and are patient. If you don't see one this summer, wait til December and they'll be popping up in classifieds.
Well I said **** it and bought a Twisted Sounds TS1.8k. Mainly just to support a ND based company. I may be foolish for doing this. But I gain a 1 yr warranty and the dealer is only 105 miles from me.
Kind of made a decision alot of my peeps have been telling me for a while. And thats keep it local. Bought my subs from TrafikJamz out of Fargo, ND and now my amp from Woods Audio out of Bismarck, ND. When I get ready to upgrade the rest of my speakers I will hitup Chuck at TrafikJamz and buy another Twisted Sounds amp to push them.
Never touched either the twisted or the sundown, but they should put out roughly the same power?
Well after talking with the owner of Twisted Sounds sold me on the idea of switching over. Being locally owned and operated is a pretty good deal for me. If something goes wrong, getting it warrantied should not be a problem
I'm pretty certain it's all psychological for you at this point. I doubt anything was going to happen to the Sundown, but sometimes you just need something else. Though, I hope that something else really gets you where you want to be.
It's an addiction for ALL of us, or you are fuqqin lying to yourself. Every time I turn it on, I am asking myself; What else 'needs' upgrading. Don't judge me, you know I'm right, lmfao....but seriously, right?
It's true. Now I'm interested in putting together home speakers. Hopefully this is cheaper //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
In all honesty the twisted ts1.3k is comparable to that synergy cause it does 1500 certified... That 1.8 will be putting you well into the 2ks that's why I'm gonna get one to replace the 2200.1d Orion amp cause it's of equal output and probably built of better components
The Synergy did almost 2.3k at 1 ohm, 13.8v
Did 2.6k uncertified
AMM-1
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
els1989
