Twisted Sounds or Synergy
AnthonyO
Budget Banger Connoisseur
Okay, I have made up my mind that I am going to replace the Sundown SAZ1500v3. Plan on buying this weekend.
So, which would you buy:
Twisted Sounds TS1.8k $325
Specifications
Model Code TS1.8k
Continuous power output @ 14.v Input:
-RMS power, 4ohm mono : 450W x 1CH
-RMS power, 2ohm mono : 900W x 1CH
-RMS power, 1ohm mono : 1800W x 1CH
-RMS power, 4ohm strapped : 1800W x 1CH
-RMS power, 2ohm strapped : 3600W x 1CH
Signal to noise ratio : >90db
Low pass frequency crossover : 30Hz-250Hz
Subsonic filter : 10Hz-60Hz
Bass boost : 0-12db
Phase shift control : 0-180 degree
Frequency response : 10Hz-350Hz (+/- 1db)
T.H.D Continuous @ 4ohm, 100Hz :
Efficiency @ 4ohm, 100Hz : 88%
Input sensitivity : 10v-200mV(+/- 5%)
Dimensions (Length) : 222(W)x52(H)x435(L) mm
Operating Voltage : DC 9V-16V
Reccomended Fuse rating : 200A (400A linked)
or
Synergy WFO15.1D $350
Number of Channels:
Power 14.4 VDC - 1 ohm:
1,500W RMS
Power 14.4 VDC - 2 ohm:
800W RMS
Power 14.4 VDC - 4 ohm:
400W RMS
Bridged Power 14.4 VDC - 2 ohm:
4,240W RMS
Input Sensitivity:
6V ~ 0.2V
Signal to Noise Ratio:
90dB
Frequency Response:
10Hz ~ 350Hz
Crossover:
Subsonic Filter:
10Hz ~ 60Hz
LPF (Low Pass Filter):
30Hz ~ 250Hz
Bass Boost @ 45Hz:
0 ~ 12dB
Phase Shift Control:
0 ~ 180 degree
Working Voltage:
8.5V ~ 16V
Efficiency:
86%
Recommended Fusing:
200a External
Dimensions:
242mm(W) x 55mm(H) x 439mm(L)
I know, thats why I am buying this weekend....lol
But the Synergy is on sale usually $549
In all honesty the twisted ts1.3k is comparable to that synergy cause it does 1500 certified... That 1.8 will be putting you well into the 2ks that's why I'm gonna get one to replace the 2200.1d Orion amp cause it's of equal output and probably built of better components
Specifications
Model Code TS1.8k
Bass boost : 0-12db
or
Number of Channels:
1,500W RMS
800W RMS
400W RMS
4,240W RMS
Input Sensitivity:
6V ~ 0.2V
90dB
Frequency Response:
10Hz ~ 350Hz
Crossover:
Subsonic Filter:
10Hz ~ 60Hz
30Hz ~ 250Hz
Bass Boost @ 45Hz:
0 ~ 12dB
0 ~ 180 degree
Working Voltage:
8.5V ~ 16V
Efficiency:
86%
Recommended Fusing:
200a External
Dimensions:
May've missed it, but why are you replacing it?
Come on, man. You've been here long enough. You know you're not gaining anything except a $400 hole in your wallet. Your amp should be solid, no way you'll hear any difference.
To be honest i am hoping to get better SQ from another amp. This sundown does what its intended for and thats put out wattage. And I would only lose about $100. Cause I can sell this sundown easily. I may be barking up the wrong tree. May buy one of these and still not get what I am looking for. But I will never know unless I try.
I strongly advise against that. You're running a 1.5kW amp at 2 ohms. You're not using it to its full potential. If your box is right, I'd get another sub and run it at 1 ohm if I were you. You're looking for more power, that's what will be your SQ. There's a debate about SQ as far as mid/high amps go, but as far as subs...no way. Good damping and power is all you need. Reliability doesn't hurt either. The sub and enclosure is what determine SQ, the amp just needs to provide plenty of juice.
AnthonyO
AnthonyO
Minot, North Dakota, United States
els1989
