tweeter replacement
jrobie79
I have a set of the PPI 356cs and for what ever reason, cant figure it out, one of my tweeters **** the bed; other one works fine, wires have continuity, so w/e. I havent had much luck finding replacements specific to that set, so I was wondering if anyone had any recommendations of what I should use to replace them....any input appreciated.
did you swap the working tweeter and non-working tweeter? it may be that the crossover has a bad cap.
PPI was bought out, blame the parent company.
Montebello, Calif. — Precision Power (PPI), the popular amplifier brand of the early ’90s, was purchased from Directed Electronics by Epsilon Electronics for an undisclosed sum.
Epsilon also owns brands including Power Acoustik, Farenheit, SPL, Kole Audio and Soundstream Technologies.
Yeah I swapped the good tweeter to the other side and it works fine, everything checks out aside from the tweeter itself, checked amp settings and head unit settings, its all equal so as far as I can tell its just the tweeter
ok, then i recommend buying two replacement tweeters so they sound the same. make sure the impedance is the same. the frequency response will be similar if the domes are the same size. larger dome sizes are ok to use.
what to get depends on your budget. you can check Parts Express or Madisound for replacement tweeters.
just found this information out:
freq response: 60Hz - 22kHz
sensitivity: 87db
impedence: 4 ohms
Fs: 65.96 Hz
Re: 3.4 ohms
Qms: 5.91
Qes: .65
Qts: .58
L1: .5
Vas (L): 7.38
Mms (Kg): .13
Cms: .437
Bl: 5.38
Xmax: .11328
Take a couple pics of the tweeter w/o the grill and post it here. Don't use your craptastic cell phone camera either; use a digital camera and get some in-focus close ups. There's a 100% chance that PPI didn't make those tweeters and there's probably something similar, if not exact, you can get OTC.
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
530
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
Tons of options in that budget, including the cost of installation,
10
991
It'll look like a "Hawaiian professional" did your install then 🤣
17
jrobie79
jrobie79
Eastern Massachusetts
disturbed471985
    Jun 1, 2024
    May 31, 2024
