Tweeter recommendations
  • 6
SlugButter
CarAudio.com VIP
4,660
2,138
arizona
I purchased some bamboo paper cone Tang Band 3.5 inch full range speakers to run as a midrange in a 3 way active front stage. Made some temporary pods from the 3 inch cardboard core from my sound deadener, since the cutout is 3 inches for the speaker. I don’t have the 8 channel amp I am going to use as of yet so I decided to run these wide range from 250-20,000 HZ just to test them out. Midbass is CDT 6x9 woofers. These Tang Bands have better highs than my Dayton audio tweeters do. I’m almost considering going without a tweeter now at all and possibly doing dual sets of these on the side of the pillar. It’s hard to believe a speaker without a tweeter would sound better than actual tweeters. Now it looks like I’m in the market for a much better tweeter. Something in the 50 watt area give or take. recommendations would be welcomed.
Boss Audio TW-12. I have a set with some Blues Audio components and they blend awesome. I got them at Autozone for $21.
Those Tang look fancy in the pods.
They are pretty cool speakers. The magnet is almost as large as the cutout which made them a little difficult. I had to solder the wire on because the spade connectors wouldn’t clear the cutout. They can handle some good wattage with the high pass crossover set at 250 HZ.
I actually have a set of Dayton soft dome and Dayton metal dome tweeters. The soft domes is what I was running and they sounded ok with a 3500 HPF. Maybe if I run the Dayton tweeters at a much higher crossover they will sound better.
I prefer soft dome for metal domes tend to be harsh to my ears. The bigger the tweeter's diameter the better it plays with the 3500 Hz x-over point.
View attachment 48612View attachment 48613View attachment 48614
Those are really sweet looking mids.
Downside for you - these are 15w RMS
No, the $500 does not include the amp, I'll e-check em out. I appreciate it Do you have any specific recommendations? There is a lot of...
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
415
Tons of options in that budget, including the cost of installation,
10
649
It'll look like a "Hawaiian professional" did your install then 🤣
17
SlugButter
CarAudio.com VIP
SlugButter
arizona
AnthonyO
pfft
    May 1, 2024
pfft
    May 1, 2024
