Tweeter help!
tony1977
My tweeters started shutting off at high volumes and come back on when the volume is tuned down for a few seconds. What causes this to happen? Im running them off boston 6.4 crossovers with boston 6.5 and the tweets are rockford punch series. Worked fine for about 3 weeks now they are shutting off. Any suggestions? If it was the amp you would think it would happen to the mids also.
The crossovers have a switch for the tweets that say flat or -3db. They are currently set at -3bd. What's the differance of these settings and could this be causing my problem?
It could very well be.Run through them,and see.I like mine set @0,or +3-6db,depending on the xover.Try running through the db settings to see,but, Id still check the tweet for Ohm reading.
tony1977
tony1977
Webb City Mo
audiobaun
