Tweeter crossover point?
ccajun4real
I am running my Orion tweets straight from the amp and am using the HPF. I need to know what to set the crossover point at? The selector goes from 80-2.5Hz. I have them set at about 1.9-2.0 right now. Want to make sure I will not damage them. Thanks
Cajun
I think 2k hz is even a little low... horns are the only high drivers I'd have hooked up that low.
I'd get with Orion and get some little passive x-over in there, rather than use the amps most likely shallow (probably 12db/octave) x-over, which is probably way too low.
Some tweets, such as some Morels, will go that low confidently //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Orions..ehh....I'd follow Squeak's advice...
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif
On a steep slope (24db/oct), I can think of quite a few that wouldn't have a problem handling 1.5khz or so
ccajun4real
ccajun4real
Watertown, NY
ccajun4real
michigan born
    May 14, 2026
michigan born
    May 14, 2026
