stud(k)muffin
first of all, the amp turn-on wires....can i connect all 3 turn-on wires (i have 3 amps) and then connect it to my headunit?? Second of all, which wire (or wires) do i connect the turn-on wires to?? On my headunit there is a power wire, a ext. wire and the antennna wire. From what ive read, it looks like i could use all 3 of those and therefore each turn-on wire would be seperate. But you tell me what is best.
Also...(different subject) When wiring my dual voice coils together (the negatives together then the positives together then each to the box terminal) how do i connect the 2 coils together?? Cut the wire and make 2 seperate ones? or can i just strip the insulation off in the middle and keep a continuous wire to run through both negative (or positive) speaker terminals and then run it to the box terminal?
