Turn on wire won't turn on my amps
ThatOneGuy36
ok so I have a keenwood ddx372bt and a Rockford fosgate prime to go with to mtx's and a factory amp. I used to have an mtx's amp with the woofers and everything worked fine but when I replaced it with the prime, the only thing that worked was the head unit. I found out that the turn on wire is not able to turn on both the factory amp and the prime. Everything goes back to normal when I unplug the turn on wire from the prime. I tried just hooking up the prime to the ignition wire that goes to the head unit and all it did was pop the fuse. I don't know why it even would pop the fuse either and I ran out of ways to fix it. Please help me my car has been torn apart for days!!!
The RF's turn on circuit might draw more current than the MTX.
You may need to use a relay on the turn on wire.
Connecting Additional Devices to the Remote Turn On Wire Using a 30 amp SPDT relay, connect terminal #87 to constant 12 volts positive with a fuse rated to the sum of the additional accessories you've added and the components you need to turn on. (If you have two fans rated at 5 amps each and a neon light rated at 10 amps, you would use a 20 amp fuse plus 200 ma for each amplifier and processor.) Connect terminal #85 to ground, terminal #86 to the remote turn on wire from the head unit, and terminal #30 to each accessory with an appropriate fuse. A fuse (not shown) could also be used between the output of the relay (#30 ) and the remote turn on wire of the amplifiers and/or processors for extra precaution.
How to Wire Relays - Connecting Additional Devices to the Remote Turn On Wire
ThatOneGuy36
ThatOneGuy36
Kearney,NE
Boomin_tahoe
