Turn on "thump"
thats usually a turn on problem in the amp.....ffrom what I know I thought you couldnt get rid of it unless you put something a soft turnon switch or something....this is more of an ignorance post trying to get correct information than stating fact.....havnt dealt with that in a long time because all high end amps dont have that problem
Originally posted by XCivic thanks dude.....
It doesnt act or thump anymore....
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
what do you mean----thanks??? how did you fix it?
Originally posted by mr4pto thats usually a turn on problem in the amp.....ffrom what I know I thought you couldnt get rid of it unless you put something a soft turnon switch or something....this is more of an ignorance post trying to get correct information than stating fact.....havnt dealt with that in a long time because all high end amps dont have that problem
turn on tumps don't aways come from the amp
Originally posted by mr4pto yeh thats what i figured, its not from the headunit or anything turning on, its from the amp itself turning on.
a turn ON tump can be caused by and upstream processor powering up AFTER the amp. if the upstream processor isn't of good design--- a signal thump can be sent down the RCAs an the amp will magnify it
XCivic
XCivic
Baton Rouge, LA
soundgy45
