tuning, whats your tuned to?
thanks for the replys guys, i really want to tune mine to 35hz, i just cant figure out why bassboxpro is making it so long, like 139 inches long port to do that... port experts please help... before port my enclosure is 6.375 cubes, and my port area is 12.5 x 8.. how long to tune to 35hz?
Done by hand:
This formula is also from "The Loudspeaker Design Cookbook". It tells you how long you need to make the vent.Fb - is the tuning frequency of your enclosure in Hertz.
Lv - is the length of your port in inches.
R - is the inside radius of your vent tube.
Vb - is the internal volume of your enclosure in cubic inches. To convert cubic feet to cubic inches, multiply by 1728.
If you want to calculate square vents, the formula below will give you the value of R to use in the formula above.
In the formula above, a is the area of your square vent (height x width), and Pi (Pi) is approximately 3.141592.
For your box (approximated port using a round port of equal area):
12.5 * 7.25 = 90.625
sqrt( 90.625 / 3.14 ) = 5.37
Lv = ( 1.463 * 10^7 * 5.37^2 ) / ( 35^2 * 6.375 * 1728) - 1.463 * 5.37
Lv = 23.4"
Make the acutal port about 2 feet long and you're good!
Hope that helps!
Done by hand:
Lv = 23.4"
Hope that helps!
i totally get that man, and i cant understate how much i appreciate it.. but i thought, and im a noob at these things, that once you get your length, dont u subtract that from the volume then recalculate? it just seems like calculating it using 6.375 and it giving u a length, isnt factoring in the loss of volume after adding the port...
when designing a box you add the port to the actual box volume to to come up with the gross internal volume which should be that of the box and port together
jeepintn
jeepintn
Greenbrier, TN
Worlddre
